Page 1 of 4
750 Paso front brake adapters to swap 320 rotors to M1R
Posted: Tue Jan 08, 2008 12:57 pm
by Finnpaso
Have anybody done such adapters to 750 M1R fork with 4 piston "black" Brembos, or "gold line" 4 piston Brembos???
Now i have normal cast iron original 280mm rotors with adapters to 4 piston black Brembos, but planning in future 17" conversion with same calipers to original M1R fork, but with 17" wheel and 320mm rotors.
All info will be welcome :thumbup:
Re: 750 Paso front brake adapters to swap 320 rotors to M1R
Posted: Tue Jan 08, 2008 3:26 pm
by ansim
I have made a set for 65mm spacing.
Link to picture: http://alltomingenting.no-ip.info/paso/ ... apter.html
Posted: Tue Jan 08, 2008 3:54 pm
http://www.box.net/shared/lscrqbkkbx
(also with 65mm brakes)
Ansim, the Autocad file download doesn`t work. Can you fix it or send me the file ? I would like to add this info to the downloads if you don`t mind.
Posted: Tue Jan 08, 2008 4:41 pm
by ansim
Here is the autocad file in Autocad2000 version,
http://alltomingenting.no-ip.info/paso/ ... totype.dwg
NOTE:
This adapter is for orginal Oscam wheel with 280mm rotor and orginal M1R fork.
Sorry for this. Remembered wrong.
Here are link to photos with mounted adapter on my Paso.
http://alltomingenting.no-ip.info/gallery/album04
edit 2008-01-09 09:58: Not Brembo, Oscam
Posted: Wed Jan 09, 2008 8:33 am
by Finnpaso
Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork. :thumbup:
Posted: Wed Jan 09, 2008 9:11 am
by ansim
It seems to be very tight with a 320 rotor/disc and 16" wheel.
See my pictures with 280 rotor,
It's tight with 4piston Brembo/280 rotor and a bigger rotor/disc will probably make it more tight.
I doubt that a 320 rotor won't fit at all.
But with a 17" wheel it will be ok, as you plan, Finnpaso.
With some measurement the adapter can be modified to fit a 320 rotor/disc.
Posted: Wed Jan 09, 2008 11:08 am
by persempre907
Finnpaso wrote:Yes, i meant adopters between 320mm normal Ducati rotors / 4 piston Black Brembos(or early "golden line" Brembos) / original 750 M21R fork. :thumbup:
Here there is the conversion to 320 mm. rotors, 40 mm. calipers (Brembos black or earlier goldline) keeping the 16" wheels.
http://www.geocities.com/750paso/paso/4 ... sult12.htm
http://www.geocities.com/750paso/paso/4pbrake/brake.htm
Posted: Wed Jan 09, 2008 12:47 pm
by ansim
Nope, it's still the 280mm rotors and 16" wheel.
Check these pictures, http://www.geocities.com/750paso/paso/4 ... sult12.htm
But it is not so tight with 40mm spacing calipers.
Posted: Wed Jan 09, 2008 2:10 pm
by persempre907
ansim wrote:Nope, it's still the 280mm rotors and 16" wheel.
Yes, it's right, I was mistaking.
They are the stock rotors!!!
Sorry :oops: .
However, it will not to be too hard make the right calipers holes to fit with the 320 rotors.
Posted: Wed Jan 09, 2008 6:34 pm
guys, if you just check what I posted. That`s a M1R fork with 17" wheels, 320mm discs and 65mm Brembos + adapters.
Antti, it seems not clear, do you want to switch to 17" with these brakes or keep the 16" ?
Posted: Wed Jan 09, 2008 8:01 pm
by ansim
True G. :mrgreen:
They looks great and it is an approved mod :D .
Posted: Thu Jan 10, 2008 11:41 am
by jcslocum
A,
Can we get an update on the Mega Squirt install???
Posted: Thu Jan 10, 2008 1:22 pm
by Finnpaso
Surely i make same time 17" conversion with original 907 wheels, so i meant 17" Ducati rim. :thumbup:
Posted: Tue Jan 22, 2008 7:51 pm
by Christian
I have done adaptor for M1R forks with 17" wheel and 320 mm rotor.
See http://zattol.com/perso/download_f.html
Bye
Posted: Thu Jan 24, 2008 4:43 pm
by Finnpaso
I mean adpters for OLDER black coloured 4 pistons, or OLDER golden line Brembos WITH 40mm hole distance. Those Yours are for newer calipers...
