Similarities 907-750?
What parts are interchangeable between a 907 -91 and a 750 paso -90?
Re: Similarities 907-750?
Not too much stuff.
The fairings and the tank are different. Perhaps the rear fairings can be fitted.
The mirrors, the handle-bars (I don't know about the master cylinders, but the front levers are the same), the footrests and the brake and the gear pedal, the headlight and the taillight.
I hope don't forget anything.
- Finnpaso
Side panels are same. Also hole rear light system and that "scoop" behind sadle are same.... "undertray"(under saddle) and rear mudguard are same. Mot so many other things.... If you think 750 for spare parts to Your 907, i wouldnt go that way... Not so much common things...
Finnpaso wrote:Side panels are same.
If you mean the air conveyors on the side fairings, the 750 ones are fitted by 5 bolts, the 906/907 ones are fitted by 4 bolts.
rear side panels
passenger grab handle
swingarm linkage
seat
lower frame rails
horn
(starter relay ?)
oil and airfilter
swingarm linkage
seat
lower frame rails
horn
(starter relay ?)
oil and airfilter
The whole keys kit.
sure ? Doesn`t one ignition switch have spade and the other round pin connectors ?
Don`t know about the 907ie but I´ve seen this difference on other Duc switches.
- Finnpaso
i mean rear side panels are same! I didnt mention main fairings.... Main fairings are totally different.... Here we call those panels under seat side panels..... sorry.
As Antti told, if you really mean looking for a spare bike, you could search a Paso 906.
She's much more common parts with the 907: engine, fairings, dashboard...
Not looking f parts bike.
Just thinking if I should save a lightly crashed & negelected Paso
I saw
in the attic at a car shop.
krakan
Hi Gert, was that a 750 or what that you looked at that car dealer??
I think
you definetly should save it no matter what!!! too few are left anyway.
Krakan 907 red
Krakan 907 red
Yep, 750.
Feel I have to save it, can`t let it just be dumped.
Too much work/money to get it decent, thinkin of maybe parting it out.
- Desmo_Demon
Do they both use the Marzocchi M1R forks?
- Finnpaso
Yes, they use, BUT different model M1R...
