Page 1 of 2
Similarities 907-750?
Posted: Thu Feb 07, 2008 2:50 pm
by Tamburinifan
What parts are interchangeable between a 907 -91 and a 750 paso -90?
Re: Similarities 907-750?
Posted: Thu Feb 07, 2008 6:05 pm
by persempre907
Not too much stuff.
The fairings and the tank are different. Perhaps the rear fairings can be fitted.
The mirrors, the handle-bars (I don't know about the master cylinders, but the front levers are the same), the footrests and the brake and the gear pedal, the headlight and the taillight.
I hope don't forget anything.
Posted: Thu Feb 07, 2008 7:16 pm
by Finnpaso
Side panels are same. Also hole rear light system and that "scoop" behind sadle are same.... "undertray"(under saddle) and rear mudguard are same. Mot so many other things.... If you think 750 for spare parts to Your 907, i wouldnt go that way... Not so much common things...
Posted: Thu Feb 07, 2008 9:36 pm
by persempre907
Posted: Fri Feb 08, 2008 9:55 am
rear side panels
passenger grab handle
swingarm linkage
seat
lower frame rails
horn
(starter relay ?)
oil and airfilter
Posted: Fri Feb 08, 2008 6:17 pm
by persempre907
The whole keys kit.
Posted: Fri Feb 08, 2008 7:47 pm
sure ? Doesn`t one ignition switch have spade and the other round pin connectors ?
Don`t know about the 907ie but I´ve seen this difference on other Duc switches.
Posted: Fri Feb 08, 2008 10:13 pm
by Finnpaso
i mean rear side panels are same! I didnt mention main fairings.... Main fairings are totally different.... Here we call those panels under seat side panels..... sorry.
Posted: Sat Feb 09, 2008 9:22 pm
by Tamburinifan
OK, thx guys!
Posted: Sun Feb 10, 2008 9:05 am
by persempre907
As Antti told, if you really mean looking for a spare bike, you could search a Paso 906.
She's much more common parts with the 907: engine, fairings, dashboard...
Posted: Sun Feb 10, 2008 11:28 am
by Tamburinifan
Not looking f parts bike.
Just thinking if I should save a lightly crashed & negelected Paso
I saw
in the attic at a car shop.
Posted: Sun Feb 10, 2008 12:26 pm
by krakan
Hi Gert, was that a 750 or what that you looked at that car dealer??
I think
you definetly should save it no matter what!!! too few are left anyway.
Krakan 907 red
Posted: Sun Feb 10, 2008 3:10 pm
by Tamburinifan
Yep, 750.
Feel I have to save it, can`t let it just be dumped.
Too much work/money to get it decent, thinkin of maybe parting it out.
Posted: Mon Feb 11, 2008 3:55 pm
by Desmo_Demon
Do they both use the Marzocchi M1R forks?
Posted: Mon Feb 11, 2008 4:10 pm
by Finnpaso
Yes, they use, BUT different model M1R...
