found a 16" tyre??
zap
found a 16" tyre??
Post by zap »
hi :D ,
While i was looking for new tyres, i checked for tyres that might fit the original paso rims and i found something that might fit the rear wheel.
Please correct me if i'm wrong.
http://www.rodamoto.es/OnLine/IN/productoId.aspx?Id=167
And for the front, if you lift your fender a little:
http://www.rodamoto.es/OnLine/IN/productoId.aspx?Id=22
If it fits, it is a very cheap and better alternative.
let me know, :beer: ab.
Re: found a 16" tyre??
it seems to be tight to fit a 150/80-16 so I guess a 170/70-16 has the same problems. Then it`s only HR rated and a tire for tourers.
I was looking into a 180/60-16 Avon, that was the only VR rated tire in that size and not made for tourers, unluckily meanwhile that model was discontinued also.
