650ss alazzurra (pantah motor)
Debonair
Post by Debonair »
Can anybody tell me if the 650 Alazzura pantah motor is the same as the 750 paso?
May have found a parts bike but I want to make sure before I buy it!
Re: 650ss alazzurra (pantah motor)
Post by jcslocum »
The place that really makes a difference is where the swinfarm attaches. You might want to post this to the Pantaheads list. I'd be interested in the asnswer...
When did they swap the direction of the rear head? I know the 750 F1 had the carb in the back, but I don't remember which way the Pantah motor had it. Clutch and gearbox is the same. Wheels would probably be 18" in back an maybe a 19" in front. Frame and body work are completely different. In short, not much matches up. Ducks of a different feather, if you know what I mean. Not a good donor bike for a Paso. It's its own project.
Cheers.
Debonair
Post by Debonair »
Thanks for that info Ducinthebay. I will be staying away from that one....
ducapaso
Post by ducapaso »
ducinthebay wrote:When did they swap the direction of the rear head? I know the 750 F1 had the carb in the back, but I don't remember which way the Pantah motor had it. Cheers.
I met something about swapping because of the production of Cagiva Elefant.
such a bike requires different space for the rear shock adsorber
