650ss alazzurra (pantah motor)
Posted: Fri Mar 28, 2008 1:09 am
by Debonair
Can anybody tell me if the 650 Alazzura pantah motor is the same as the 750 paso?
May have found a parts bike but I want to make sure before I buy it!
Re: 650ss alazzurra (pantah motor)
Posted: Sun Mar 30, 2008 11:28 am
by jcslocum
The place that really makes a difference is where the swinfarm attaches. You might want to post this to the Pantaheads list. I'd be interested in the asnswer...
Posted: Tue Apr 01, 2008 5:10 am
by ducinthebay
When did they swap the direction of the rear head? I know the 750 F1 had the carb in the back, but I don't remember which way the Pantah motor had it. Clutch and gearbox is the same. Wheels would probably be 18" in back an maybe a 19" in front. Frame and body work are completely different. In short, not much matches up. Ducks of a different feather, if you know what I mean. Not a good donor bike for a Paso. It's its own project.
Cheers.
Posted: Fri Apr 04, 2008 4:29 am
by Debonair
Thanks for that info Ducinthebay. I will be staying away from that one....
Posted: Fri Apr 04, 2008 4:09 pm
by ducapaso
ducinthebay wrote:When did they swap the direction of the rear head? I know the 750 F1 had the carb in the back, but I don't remember which way the Pantah motor had it. Cheers.
I met something about swapping because of the production of Cagiva Elefant.
such a bike requires different space for the rear shock adsorber
