Rubber fairing nuts, do they fit the 907 I.E.??
nicoducati82
Post by nicoducati82 »
Hi all...well...while finding something to buy for my bike, I found this item on ebay...the seller doesn't know if they fit the 907 I.E....what do you think?
Saludos
Nicolás
http://cgi.ebay.com/DUCATI-paso-750-906 ... .m63.l1177
Laddie907
Re: Rubber fairing nuts, do they fit the 907 I.E.??
Post by Laddie907 »
I have just bought the same ones from Giovannimoto - just a larger set...
if they fit the 906 and 851 they are supposed to fit the 907ie.
I can let you know when they arrive if they fit...but am confident they will be OK.
Laddie907 wrote:if they fit the 906 and 851 they are supposed to fit the 907ie.
They will fit. :thumbup: :thumbup: :thumbup:
Normal wellnuts.... can be found from many nut/screw shops :smoke:
Kurt
Post by Kurt »
Desomtimes.com sells these in the US. My Duc dealer has ordered the genuine part for me -- I think the lip is a little different. When they come in, I will report and post -- along with measurements on the missing "bullets" and grommets at the tank/panel attaching points, per other thread.
- Kurt
ducbertus
Post by ducbertus »
Hi Nico,
original fit the best. desmotimes seem to offer also goods ones.
I bought 50 pieces at a regelar fastener shop for € 22 to find out that the lip was over 5 mm thick instead of 1 mm.
so I grinded the lip down to 1 mm. with a belt grinder.
worked very good. :)
ducbertus
ducbertus wrote:I bought 50 pieces at a regelar fastener shop for € 22
The Ducati dealers sell them for €. 1,98 each!
ducbertus
Post by ducbertus »
yep,
that's why I bought them NOT at the dealer.
If a nut is a little out of shape, I just put in an other. After grinding down the lip, which doesn't take a minute with a belt grinder :lol:
ducbertus
I have also bought such from normal nut/screw shop and they fit quite perfect... I havent made any modifications to wellnuts, or to they holes... :thumbup:
tewsy
Post by tewsy »
I can also recommend the wellnuts fom Desmo times, they fit well.
227708
Post by 227708 »
Desmoparts.com in Houston, TX, also carries fairing wellnuts. They're .70@ for M6's, and are an almost perfect replacement for factory Ducati parts, and ship quickly. The company also carries a variety of stainless buttonhead fasteners, though I personally prefer the original gloss black.
robert
'93 907ie
'75 Norton 850
robert
'93 Ducati 907ie
'75 Norton 850 Commando
'98 BMW K1200RS
'85 VW Vanagon (to haul parts for the bikes...)
Laddie907
Post by Laddie907 »
the fairing rubbers from Giovannimoto arrived and fit OK.
while "browsing" I found this MotoGuzzi site:
MG CYCLE
601 Ogden Ave
Albany WI 53502
USA
Phone: (USA) 608-862-2300
FAX: 608-862-2015
Toll Free Order: 888-464-2925 (888- 4-MGCYCLE)
EMAIL info@mgcycle.com
the web site lists various rubber components that may suit the 907;
It would be handy to get someone from the USA to check out interchangeability
tank hold down rubbers
funny under tank rubber bits to clip on side cover
side cover end bits that slide onto the rear frame spigots
6mm thread vibration mounts for ECU & regulator
