The temperaguage on my dash is not showing any increase (in fact nothing at all) in temp as the engine heats up. This, after the fixing of the Starter Sprag. Probably caused by draining of the coolant etc. I have topped up the system, there is fluid all through the cooling system, both above and below the thermostat, in the radiator etc.
I am assuming there is just a disconnection somewhere in the wiring from the sensor to the guage...but where. Anyone experienced this previously and can point to a possible connector?...I have looked and cant find the problem.
If the sensor has gone east, I am assuming the radiator fan wont start also???
Dazed and confused......yet again.
Oh, the starter now works brilliantly, first push of the button...the original spring must have been 2 meters long I think.
