Hello All,
Via Windtrading Srl in Italy I'm trying to convince Silmoto to manufacture another set of the following open exhausts from the so-called uprating kit:
- 40mm horizontal exhaust pipe 0370.84.023
- 40mm vertical exhaust pipe 0370.84.033
- open right hand exhaust 573.1.003.1A
- open left hand exhaust 574.1.003.1A
Anybody else interested in a set?
Mark
Open Silentium Exhaust
Re: Open Silentium Exhaust
Hi Mark,
do you happen to know the difference between the 0370.84.020 and the 0370.84.023 ?
Guess you do if you want to have it made. I`m wondering as the vertical tube 0370.84.033 is used on both headers so they do have the same diameter. Where`s the difference ?!
Gerhard
Gerhard
Hi Gerhard,
I was under the impression that the standard headers have a 36mm diameter. Great news if I only need the open exhausts!
Mark
Mark
