Page 1 of 2
Check your rear shock!
Posted: Sat May 09, 2009 7:33 pm
by paso904
Hello All,
I have owned my 1989 906 Paso from new and last week I took it for its annual MOT check. The tester mentioned a small amount of play in the rear suspension unit which we guessed was due to some wear in the upper bush mounting. Yesterday I investigated it and had an unpleasant surprise when I found that the top 'eye' had a crack right through it:
http://docs.google.com/Doc?docid=dgv8c3 ... p&hl=en_GB
I have posted an appeal for a unit in the for sale section.
David Harvey - Sussex - England
Re: Check your rear shock!
Posted: Sat May 09, 2009 9:01 pm
by persempre907
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
How many Kms have the bike?
Posted: Sat May 09, 2009 10:13 pm
by jcslocum
Theres a shock on ebay right now. That might be able to be welded as well.
Posted: Sun May 10, 2009 9:23 am
by persempre907
jcslocum wrote:That might be able to be welded as well.
I don't know. I'd fear the welding could break again.
Posted: Sun May 10, 2009 6:07 pm
by paso904
Hello All,
Many thanks for your replies. The unit is the original one and has covered 88k kms. I did wonder about having it welded but I would be worried that the 20 year old alloy would just break again somewhere else. I have had a look at http://www.hagon.co.uk and it looks like a suspension unit from a 916 will be a direct replacement. Can any one confirm this please? (If so, it will make finding a replacement on e-bay easier). For the time being I will try to source a replacement in the UK in view of shipping costs.
Thanks again for your help.
Regards,
David Harvey - England.
Posted: Sun May 10, 2009 6:13 pm
definetely not. The shock of the Paso is much longer. (The one of the 916 is mounted on the upper side of the swingarm and is therefore shorter)
Posted: Wed Oct 14, 2009 1:15 am
by crmac
Have you sorted the shock yet?
I had this happen on my 1990 Paso years ago. I had it welded and it's been OK since then.
Posted: Wed Oct 14, 2009 8:37 am
by mika750paso
Just to remind, rear shocks for Paso 750/900, www.bitubo.com.
Posted: Fri Oct 16, 2009 5:30 pm
by paso904
Hello All,
Many thanks for your helpful replies. I have had my unit welded and touching wood, all is well.
Posted: Fri Oct 16, 2009 10:40 pm
by Tamburinifan
The bushing in the shock had a crack or the whole upper part of the shock had a crack?
Posted: Sat Oct 17, 2009 5:39 pm
by paso904
Hi Gert,
It was the alloy surrounding the upper bush that had a crack. I took a photo if you are really interested.
Posted: Sat Oct 17, 2009 7:20 pm
by higgy
pictures are always helpful for the wannabe Paso enthusiast so they can know exactly what to look for in considering a Paso purchase. :thumbup:
Posted: Sun Oct 18, 2009 10:38 am
by Tamburinifan
I have a small amount of play, too. Will fix it this winter.
A pic would be nice to see what problems lies ahead of me.... :-(
Posted: Sun Oct 18, 2009 11:17 am
by higgy
and seasoned owners too :thumbup: :lol:
Posted: Sun Oct 18, 2009 5:27 pm
by paso904
Hello All,
A photo of my formerly cracked (and subsequently repaired) shock can be found at:
http://docs.google.com/View?id=dgv8c3qz_342cffkbhf8
I must stress that there was no play whatsoever in either of the bushes (pretty good after 65,000 miles). The small amount of play was entirely due to the crack.
