Freeplay front sprocket?
Posted: Sun May 10, 2009 7:13 pm
by Tamburinifan
Is there any freeplay for the front sprocket to wiggle a little on the shaft?
Re: Freeplay front sprocket?
Posted: Mon May 11, 2009 1:31 am
by jcslocum
Yes there is. The sprocket is a slip fit and the keeper holds it in place.
Posted: Mon May 11, 2009 10:47 am
by Tamburinifan
Thx!
Posted: Mon May 11, 2009 5:06 pm
by Finnpaso
Check anyway axle, if there is any wear signs!
Posted: Mon May 11, 2009 7:39 pm
by Kurt
... and drill the two screws for lock wire while you have them out ...
... and install a "Desmo Times Case Saver Insert" from
http://desmotimes.com/
Posted: Mon May 11, 2009 11:32 pm
by Tamburinifan
Axle no wear & Desmo Times case saver I have!
Posted: Tue Jun 23, 2009 11:49 pm
by dtrides
Speaking of front sprockets, I just ordered a 14T front sprocket from Demo Times. The new sprocket has all the spacing on one side while the stock sprocket has a equal shoulder on both sides. I am worried about chain alignment . What are you guys doing??
