Freeplay front sprocket?
Is there any freeplay for the front sprocket to wiggle a little on the shaft?
Re: Freeplay front sprocket?
Post by jcslocum »
Yes there is. The sprocket is a slip fit and the keeper holds it in place.
Thx! :)
Check anyway axle, if there is any wear signs! :smoke:
Kurt
Post by Kurt »
... and drill the two screws for lock wire while you have them out ...
... and install a "Desmo Times Case Saver Insert" from http://desmotimes.com/
- Kurt
Axle no wear & Desmo Times case saver I have! :thumbup:
dtrides
Post by dtrides »
Speaking of front sprockets, I just ordered a 14T front sprocket from Demo Times. The new sprocket has all the spacing on one side while the stock sprocket has a equal shoulder on both sides. I am worried about chain alignment . What are you guys doing??
