My bike has been sitting since last Fall. It wouldn't start up, but that was fixed relatively quick. However I discovered there was no resistance at my clutch lever. Plenty of fluid, but the lever action sounds a "quish" which I don't ever remember hearing before. Cover plate off and cleaned. No detected leaking down at that end. Pumping the handle does not affect the slave piston.
Next I lossened the bleeder valve and bled the line, refill of fluid, no bubbles....still nothing.
I removed the banjo bolt and bleeder screw and blew air in to "push" the piston out, 1mm.
Tried pulling at in with my fingernails, 1mm.
How far out should this piston come out without industrial strength pulling at it?
Still no resistance at lever at any point.
My next step is to prime the clutch mc and bleed as per recommendations in the posts I read.
Any other tips would be appreciated
