I have read questions and answers of other people who have had clutch problems and followed their advice - but still can't solve the problem.
Last time I took the bike out, there was no resistance at the lever, even after 'pumping' it, but the clutch worked ok - but straight from the grip.
The gear changes were as slick as ever and there was no creep at standstill, in gear.
I assumed that the system needed bleeding.
When I tried, I couldn't do this.
There seemed to be no movement of fluid and there was more suction on the return stroke, than pressure when the lever was activated.
The fluid looked thick and cloudy, so I changed it for new. I couldn't bleed the new fluid through the system and bought a Mity Vac which worked ok and used the vacuum to draw the new fluid and air,through.
But; I couldn't bleed the system and get the clutch to work at all.
It seems as if there is air getting into the system somewhere and I can't see that there is any fluid leaking out of the system.
All I can think is that the master cylinder needs overhauling but wanted to avoid this if possible.
I hope that someone out there has suggestions to solve this problem.
Thanks for any help.
