Piston from 750F1 ?
silverfox
Piston from 750F1 ?
Post by silverfox »
Oooops
Can you use a piston from a 1985 750 F1 in a 1988 750 Paso? :oops:
I hate winter maintainance :(
Tony
Re: Piston from 750F1 ?
Post by jcslocum »
You can use a SET of pistons from an F1. You would have to investigate if there is any real difference in the shpe, but a set should work. I think they have the same compression ratio.
