944 cylinders
93IE
944 cylinders
Post by 93IE »
Are 944 ST2 cylinders a bolt on replacement for the 907?
Re: 944 cylinders
They say so, even if some little fix is needed.
If I well remember, the RPMs counter and a few little things.
Speedmade
Re: 944 cylinders
Post by Speedmade »
Yes. The ST2 (94mm) cylinders and pistons are a bolt on deal for the 907 or 906.
The stock 906/907 cylinder can be safely bored and plated to 95mm which makes a 966cc. Pistal pistons are available from BCM or Kaemna
96mm (984) cylinders for the oil cooled motors can be easily modified to work on a water cooled motor. But you do need to bore the cases to fit those cylinders.
93IE
Re: 944 cylinders
Post by 93IE »
Would anyone know if it is worth the trouble of adding the 944 top end as far as a gain in power. The bike has Staintunes and an eprom for the slip ons. Would it need to be remapped? It runs a little on the rich side as it is now.
Re: 944 cylinders
Post by jcslocum »
You'll get a small push in HP and a nice bump in the torque. You can also add some 944 high compression pistons 11:1 or so and make an even better gain. A power commander (and dyno) would probably help with the fuelling.
I put a 1080 kit with 11:5 to one pistons in my Multi and the change was really impressive. 89 RWP and 79 Ft. Lbs of torque.
Re: 944 cylinders
ST2 heads are bolt-on except you have to make a tunnel f the rev counter mechanism.
I have done it, works well.
Re: 944 cylinders
Gert, Do U have only ST2 heads, or also sylinders with 944 cc capacity?
Re: 944 cylinders
There have been a lot of ST2 parts on ebay of late,cylinders are cheap, heads are cheap, cams cost more than the other parts combined :mrgreen:
93IE
Re: 944 cylinders
Post by 93IE »
Ist necessary to use the 944 heads with the 944 cylinders, or can the 907 heads be reused? Would they make a noticable performance?
Preston
Re: 944 cylinders
More cc, more power .... Also cams are very critical for reach better torque curve...
Re: 944 cylinders
I have the 907 cyls w the ST2 heads.
Re: 944 cylinders
higgy wrote:cams cost more than the other parts combined :mrgreen:
They say that ST2's cams design was better than the 907's stock one and excellent for all the 900 cc. engines.
