Piston Rings
Mustang505
Piston Rings
Post by Mustang505 »
Hi Guys
just interested to find out if rings are easily available your side of the world.
I was one afternoon away from completing the rebuild of my motor and managed to break the one oil ring - #$%&*&^* -!! But here in New Zealand not available nor in Australia. So Gowanloch Ducati in Sydney (quite a famous place to source old Ducati stuff for those who haven't heard about of them before) have had to order from Italy at $AUS 175.00 per set. Is going to take 2-3 weeks.
How does that compare with the States or Europe?
Cheers Clive
Clive
Re: Piston Rings
Post by jcslocum »
Just bought rings here in the USA for my F1. They were in stock at BCM Ducati in New Hampshire and they cost $106 delivered to me in NY.
Mustang505
Re: Piston Rings
Jon
is that per set or for both? Does the F1 have 3 rings - 2 compression and 1 oil?
There is a guy here who races an F1 and "i'm told" runs Nissan pistons in it. Have you ever heard of alternative pistons fitting 750 Ducatis before?
Cheers Clive
Clive
Re: Piston Rings
Post by jcslocum »
Yes the F1 has threee rings in a set. That was just for 1 set. Ducati gets big $$ for piston rings....
There are alternatives to Ducai pistons but I have never heard of a Nissan piston. If the dimensions are right then why not?? I can't imagine that they would be better than Pistal or some other real aftermarket high end pistons. Check out California cycle works online.
silverfox
Re: Piston Rings
Post by silverfox »
Clive, I'm guessing you have fixed this prob but for others there are alternatives.
Dodge Neon/Mitsubishi Eclipse rings are as cheap as (an you get 2 sets) for $93 US landed in NZ
They are 88mm x 1.2 - same as Ducati - you have to get the grooves made deeper but overall its the cheaper option.
Mine are awesome- most compression/ lowest oil comsumption I have had for 9 years !
Tony
Re: Piston Rings
Re: Piston Rings
Post by 888906 »
I'll have a look, I may have some here in Sydney.
888906
Re: Piston Rings
Post by 888906 »
I have two 750 Paso pistons new complete with rings, pins and circlips if anyone is interested. Location Sydney, Australia
