brembo brake Master cylinder
pasophist
Post by pasophist »
The 907 brake MC operates two discs and says 16mm on it. The 750 Paso MC is the same size and shape with the same viewing port (sightglass) and has no markings on it. The 2002 750 Sport (FI) has two discs- when not in "dark configuration" and has the same shape and size MC with no markings on it. Are the Paso and the 750 sport using the same 16mm part as the 907i?
Thanks,
Sheldon
Re: brembo brake Master cylinder
no, the P750 uses a smaller MC. If I remember well it`s a PS13.
Duc750
Post by Duc750 »
WHich then begs the further question, which Brembo radial to swith to? :lol:
The 19'' stock master cylinder of the 999.
Great braking!!
