brembo brake Master cylinder
Posted: Mon Oct 19, 2009 4:41 pm
The 907 brake MC operates two discs and says 16mm on it. The 750 Paso MC is the same size and shape with the same viewing port (sightglass) and has no markings on it. The 2002 750 Sport (FI) has two discs- when not in "dark configuration" and has the same shape and size MC with no markings on it. Are the Paso and the 750 sport using the same 16mm part as the 907i?
Thanks,
Sheldon
Thanks,
Sheldon
