thank you so much
ducati 906 paso ( 1990 ) cluster gauges , or dash bord
shaqy
pls help , i'm from Romania and i just buy this superb motorcycle but it has no dash bord or cluster gauges , can annybody help me with some inos about where can i bui it?
thank you so much
thank you so much
Re: ducati 906 paso ( 1990 ) cluster gauges , or dash bord
http://www.marktplaats.nl/ , --> motoren, search f ducati paso.
I saw a dash today.
I saw a dash today.
shaqy
thank you so much for the effort , but no english ?
i'm from Romania , i speak english , but nordic languages are a little bit hard for me
maybe can you help me?
eventually look for me? on this site pls?
It`s from Holland so they speak Dutch.
But I don`t think that is a problem, Dutch people are usually very good at English.
Just press the link that says email on the right, fill in naam-name & het emailadres -your emaildaress &
what you want in the commentaar box.
I think that will work.
http://link.marktplaats.nl/292992145
Welcome Shaqy,
there is a new dash on ebay, now.
http://cgi.ebay.it/Ducati-906-907-Dash- ... 500wt_1182
Good luck
Good luck
shaqy
i want to thanks all the great guys who try to help me , i finally buyed my dash bord for my bike , now i'm looking for something else , an carburator , Delorto
- Finnpaso
If You are looking Dellorto's try to find 36mm ones, as 40mm are too big for 750cc engine. Keep in mind, that You need also then throttle cable systems and new accelerator handle. Another alternative is to find Mikuni's from mid 90's Monster or Supersport. Most expensive are Kehin flat slides and they are also quite hard to find from markets.I moved first from Weber to 40mm Dellortos but at the end changed to Mikuni's. You can find from here alot of info no matter what carburators You will put to Your Paso. Good luck!
I guess he needs the carbs for a 906
No matter, you can use the same Mikuni or Keihin for the later Ducatis as well as the 40's Dellortos.
- Finnpaso
Thanks Frankie
40mm Dellorto's are fine for 906.... seems that i have still too much shit from flu in brains!
- ducbertus
hi shaqu,
the dutch dashboard has no clock. the seller lives about 25 km from my place.
look on Ebay, there's offered a complete dash for € 60
http://cgi.ebay.de/Ducati-Paso-750-Vegl ... 5639c5daba
this guy is departing a P750.
I've dealth with him once and the sale went smoothly.
ducbertus
ducbertus
shaqy
Thank you all for answers , and advices ,
Best regards from romanian bikers
