Hi, I have searched about Samco hoses and there has not been a definitive answer if the 851 will rplace most of the hoses.
What about the ST2 set, there is no picture on the site,
http://www.samcosport.com/row/bike_kits.asp?make=Ducati
Anyone got further information before I try?
cheers
Samco Hoses
- blazing928
Samco Hoses
Nigel
91 907IE - full restoration
MPL Slipper,Ceramic exhaust
Lambretta LI150 S3
87 928S4
Lambretta LI150 S3
87 928S4
- englishstiv
Re: Samco Hoses
I contacted them direct about a year ago and eventually got a reply, the result of which was they do not do a full set however if you vistied one of there main suppliers (that was here in the Uk to me) and took the Paso set to compare/match they may be able to assist. They also would not help when I even offered to send set direct to them and infact did not seem that interested in helping further
As someone reminded me they are really there to support the race circuit set so if I want a set I will need to do all the donkey work and additional cost trying different sets to make a full matching set.
Let me know if you have any better luck because they are lush.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- blazing928
Re: Samco Hoses
After a fair bit of running around today , I think the best way is to fabricate an alloy or S/S piece for the two hoses that come off the main line, [a double' TT '] and also an elbow with a outlet to the coolant tank.
Then buy what ever elbows and straight pieces and join it all up, maybe also using straight alloy pieces, like a race bike set up.
Samco makes a flex hose that doesn't collapse so that may do some of the shorter lenghts.
I have made up my mind to do this , so I will let you know the outcome!
Nigel
Lambretta LI150 S3
87 928S4
Lambretta LI150 S3
87 928S4
