friction bearing - where to buy ?!
I`m looking for a friction bearing PAP2510 P10 (which I think is currently being discontinued and replaced by PAP2510 P14). Measurements are Od 28mm, Id 25mm, W 10mm.
Any idea where I can get one ?
I encountered 2 problems so far. My usual SKF bearing dealer doesn`t have them, but can order them with a MOQ of 5 (SKF doesn`t have that size and would need to make them on demand). Price would be €16 ea. and I only need one. I`d take two if they were cheaper (in an italian price list from INA they cost only €2,03+tax).
Secondly most online dealers have a minimal order amount and I only need this.
Any input is welcome. thx
englishstiv
Re: friction bearing - where to buy ?!
Post by englishstiv »
any use?
http://www.bearingshopuk.co.uk/index.asp
or
http://www.apollobearings.co.uk/products.html
They do single item sales should be no problem to Europe and exchange rate pretty good too :thumbup:
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Desmo_Demon
Post by Desmo_Demon »
paso750 wrote:I`m looking for a friction bearing PAP2510 P10 (which I think is currently being discontinued and replaced by PAP2510 P14). Measurements are Od 28mm, Id 25mm, W 10mm.
Does SKF make one of these? What exactly do you call a friction bearing? Is it like a plain spherical bearing/"Babbitt" bearing (like those used on rod and crank journals of small block Chevy engines)?
www.skfusa.com
englishstiv, thanks a lot. I`ll try to contact them.
Terry, according to my online translator other expressions are bush/slide or sleeve bearing
Don`t know about Chevy engines, but the Duc Superlight uses one for its hanging rear caliper bracket.
http://medias.schaeffler.com/medias/en! ... /PAP..-P10
ok, found it. Just by chance I called a small store close to here and they can order them for 2 Euros something ea. :choo:
if anyone cares to know, the new P14 types are RoHS compliant (Restriction of Hazardous Substances, hence leadfree)
