Air Box Horns
dennist
Air Box Horns
Anybody have a pair of useable top air box horns lying around they do not need and will sell? I got a new top box from DNA but they no longer stock the 2 horns. Bike is running too lean, need to close off some air as box top was cut off giving way too much air. Before you ask, mufflers were totally reworked and Fast by Ferraci chip put in. Stock paper air filter is retained but still too much air. So Duc mechanic wants me to put stock box top on. Thanks for your help.
Re: Air Box Horns
Try these guys
http://ducpower.guzzitech.com/
dennist
Re: Air Box Horns
Thanks, was not aware of these guys. Just sent them an email.
- du907
Re: Air Box Horns
I'll check, may have them.
du907
du907
- du907
Re: Air Box Horns
Sorry, I have found only one of them.
du907
du907
dennist
Re: Air Box Horns
Come on guys, check all the old parts you took off your 907ie, I still need one more air horn for the stock air cover. Found one. I am sure it was the thing to do to take off the air horns for more air into the box. Thanks.
- du907
Re: Air Box Horns
Put one in the mail to you today.
dennist
Re: Air Box Horns
Thanks, more to go guys.
laverda
Re: Air Box Horns
I have a air intake horn available if you still need one. I also have a lot of other Paso parts available.
Steve
Steve
