First Major Problem
egagnon3
First Major Problem
Post by egagnon3 »
I went for a ride and filled up the bike before I got home. I left to go to the store in my car, when I came back the garage smelled like gas and low and behold a big puddle under the bike. I turned the fuel petcock off and it slowed, then stopped. This bike has Mikuni TM flat-slide carbs, and there is gas running out the overflow tube on the horizontal cylinder carb. My friend says I need to adjust the float level, not sure how to accomplish this, any ideas?
Re: First Major Problem
can you post a picture ?
You can download a pdf of the TM manual here
http://www.mikuni.com/pdf/vmmanual.pdf
Post by jcslocum »
If it wasn't leaking before and then leaking after it sounds like a stuck float. The float needle must have some junk stuck in it that keeps it from closing. Try this trick:
Turn the fuel off and let the engine run until it dies of fuel starvation. This allows the float to fall to it's lowest point and allow the junk to flow by. Then tap the float bowl with the handle of a medium sized screwdriver a few times and then turn the fuel on. The may wash the junk out of the float needle. If this doesn't do it, you'll have to pull the bowl to remove the needle and blow it out.
Fraser
year: 1986
Post by Fraser »
Sure sounds like a stuck float. Luckly the petrol went out the overflow and not down the carb and into the cylinder. Check your oil level just in case; to see if is fluctuating; full when you go for a ride, but low when you return.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
21783mike
Post by 21783mike »
I put a vacuum actuated petcock on mine between the stock petcock and the fuel pump to prevent such things.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
egagnon3
Post by egagnon3 »
Thanks for the help. The float was stuck and allowing gas to flow. The oil level is fine, nothing went into the engine. Put a reachable fuel shutoff online just in case. Runs great now, no leaks. Though I have a question, will the clock on the "dash" drain the battery if I ride every other day?
I think, it (clock) drains battery too low, if You drive "every 2. or 3. week". Surely it also depend of Your battery condition... and charge system condition... and... and... :thumbup:
egagnon3
Post by egagnon3 »
That's what I thought, I used a multimeter and it was a very low draw. But i figure it should be fine, the battery is only a month old. Thanks.
Also, this may go on forever but how do you bleed the front brakes? I can't even get a brake bleeder wrench around it, it's so close to the wheel, any ideas.
A clock that still works 8) I have yet to see one that still goes
Desmo_Demon
Post by Desmo_Demon »
Mc tool wrote:A clock that still works 8) I have yet to see one that still goes
The one on my '87 still works...keeps pretty good time, too. :thumbup: :mrgreen:
I put new liquids from bottom to top, so then if there goes any air, it comes much easier out from master cylinder. If doesnt come, then i leave master cylinder with lever overnight to such position, that air passes that upper banjo bolt, as air stays easily there. Next day i move lever very slowly many times in that same position and never after that any air in system.. Function well to me....
About tool: I have made special tool to bottom valve with cutting and weldind one normal wrench. If You let me know Your email address by PM, i can send foto to U from my wrench. :thumbup:
Post by jcslocum »
I vacuum bled with the calipers off of the mount. If you put a piece of wood in, you could pressure bleed off the mount as well.
That is another way to do it, but it needs to invest such vacuum bleeder then.... :)
PasoRoo
Post by PasoRoo »
The great idea of mounting a clock doesn't do much for battery charge (so a trickle charger is a neccessity) it does keep pretty good time.
The only way you'll reasonably fit a spanner on the bleed nipple (or even the plastic hose for that matter) is to take the caliper off the mounts. If you loosen the caliper mount bolts you can drop the caliper a centimeter or two along the disk. which gives you a bit more space. . If you don't take the caliper off the disk you don't have to worry about inserting a bit of wood and you can still open the bleed nipple with one hand.
I'm in the middle of bleeding the brakes and it's heaps of fun :? . I'm going to try the trick of inserting the brake fluid from the bottom with a syringe this time.
Mike
