Anyone knows the torque values f the 12mm bolts in the rear
suspension linkage?
My wrench is in Nm.
Torque rear linkage?
Re: Torque rear linkage?
do em up till you can just feel the thread starting to strip then very quickly back em off a flat
According to the book ,both the " back suspension nut " and the" shock absorber nut " , which are both 12 x1.5mm should be tightened to 49 - 54 nm
