BMW K1100LT fork seal vs MR-1 907IE
sgkramar
Post by sgkramar »
So, I read that the oil seals for the front forks were the same for the subject bikes, but when I bought the BMW seals they are thicker than the original (?) Ducati seals. They are enough thicker that I can't get the lock ring in above the seal to hold it in place. Did I get the wrong BMW seals, or is there another trick to get these to work?
93IE
Re: BMW K1100LT fork seal vs MR-1 907IE
Post by 93IE »
I'm no expert, but it's apparent those won't work. Are you sure you shouldn't have seals for a K100 BMW? I think that's a different animal altogether.
sgkramar
Post by sgkramar »
I got my info from this post
http://forums.ducatipaso.org/viewtopic.php?f=3&t=3889
Maybe not all parts are the same.
duc907
Post by duc907 »
My seals are much closer in size, I just can not get them seated.
sgkramar
Post by sgkramar »
My typical solution is to use the old seal, a large socket, and a hammer.
But, the stock seals from Marzocchi are still available at the Ducati dealers for €. 17...
So, I'd buy those ones :lol: :lol: :lol: :lol: .
duc907
Post by duc907 »
I just bought seals from the BMW dealer, $17.33 each, they had them in stock, exactly the same. They fit the k100 RS.
du907
Post by du907 »
The last time I replaced my seals I used the OEM 907 seals and they started leaking about month later. I took them out and replaced them with 900ss seals I just happen to have. Same outside diameter and same inside diameter. They where however a little taller. So I sanded off the rubber coating on the bottom and left out the washer on the top so I could get the retaining ring on. They have been in for about 4 years now and no leaks. The 900ss seals are more robust than the regular 907 seals.
du907
ABreeze
Post by ABreeze »
that looks like a k100 seal, not a k1100 seal. the k1100 seal is the exact same as the 907 seal.
pn-31422312928
http://forums.ducatipaso.org/viewtopic. ... 95&start=0
pasolloyd
Post by pasolloyd »
The BMW part numbers that I quoted in my post are EXACT replacements for the 907ie. They are made by Marzocchi and have the same Marzocchi part number molded into the rubber. You have the wrong seal from BMW. Check the part numbers in the post again.
'91 907ie
'96 900 SS SP
'97 900 SS CR (for sale)
'74 750 GT (since new - sort of)
'85 Pantah 600 (sold, but not forgotten)
sgkramar
Post by sgkramar »
Sure enough. Went to the BMW dealer (vs buying the pyramid replacement part online which was the wrong seal) and they had the correct seal in stock. Thanks for the help.
