Where the 36 wire cable enters the ECU,
which pin is the TPS signal?
If anyone has a wiring schematics of the P7,
much appreciated!
P7 ECU wiring?
P7 ECU wiring?
- du907
Re: P7 ECU wiring?
Pins 11 and 17
Re: P7 ECU wiring?
OK, thx,
same as you measure TPS; that is.
