Air valves top of M1R forks??
907pasonut
Post by 907pasonut »
on the Pasos the front forks have air valves up top, I think :dunno: approx 15 years ago I put approx 5psi air pressure and never checked them since, does anybody know if any pressure or what pressure should be put in there :?:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
Re: Air valves top of M1R forks??
zero, as in no pressure at all
907pasonut
thanks again higgy, I dought there will be any pressure left by now, but I will check in any case... this goes to show...if you not sure about something dont do it!! :thumbup:
Cheers Claude.
ducbertus
Post by ducbertus »
No pressure at all.
the less pressure, the better the fork respons.
the legs suck in air by them selves, and the pressure needs to be relieved by applying the valves every now and than.
bertus
