Mikuni carb fuel screw setting
Mustang505
Post by Mustang505 »
Hi
I have done a search here and on Paso forum to try find the stardard Mikuni carb fuel screw setting. i found one statement of 3.5 turns out. is that right? can anyone confirm? thanks
Clive
Foxtee
Re: Mikuni carb fuel screw setting
Post by Foxtee »
When I fitted a dynojet kit to my carbs , I took note of how many turns it took to seat the screws which was 3.5 .
The instructions then state 3.5 turns from fully seated, hope that helps :thumbup:
1990 750 Paso
2011 Suzuki Bandit 1250 S
Quite normal setting on f e a 900.
2,5-4 turns is the normal spectre if you mean Mikuni CV38 carbs w standard jetting.
The Sudco Mikuni Tuning manual is the defacto bible for any Mikuni carb and you can get a copy at this Url
http://www.sudco.com/manual.html 13.60 with s/h included,cheap by any standard :thumbup:
Mustang505
thanks Guys
Clive
