ducati paso 906cc 1990
dario
Post by dario »
just 9000 miles and is hard put in neutral wend is running, any idea for fix this problem? :cry: :cry: :cry: :cry:
streetsurfer
Re: ducati paso 906cc 1990
Post by streetsurfer »
Could it be that your idle is set too high?
A good bleeding of the hidraulic circuit :thumbup: :thumbup: :thumbup: :thumbup: :thumbup: .
Very common on Pasos.
chain tension and clutch bleeding would be the first two items to check.Going a little deeper it is also very common for the under the cover part of the linkage to need centering but this is more likely to present as missed shifts in the 4 to 5 or 5 to 6 shift. Trouble shifting to neutral is air in the clutch or chain too tight.
dario
Post by dario »
:shock: Thanks guys for your help,i' m going to check for try to find my problem.
