Dumb Question
Posted: Mon Oct 04, 2010 4:43 pm
by 2vtwin
Purchsing a 907ie, noticed it does not have the Center Stand, only the damn spring loaded side(jiffy) stand. Was the center stand an option? Thanks - Gene
Re: Dumb Question
Posted: Mon Oct 04, 2010 6:07 pm
by Finnpaso
NOT option, as EVERY 907IE had such from factory. Some are for sale sometimes in Ebay and if You know good welder, he can also do such to You.
You can also easily modifie side stand such way, that it is not "automatic" anymore. Put anotherkind screw(shorter) to it and its ok then. That curved plate (holds spring) is "passing" that holder screw then.
Sorry, i dont know, what "jiffy" means....
Re: Dumb Question
Posted: Mon Oct 04, 2010 6:22 pm
by higgy
Most likely it was removed,either for a non standard exhaust installation or some Psuedo racer thinkin he needed more ground clearance
Re: Dumb Question
Posted: Tue Oct 05, 2010 6:05 pm
by Finnpaso
It hits sometimes to surface in race track, i see also scratches in my both 907's.
Re: Dumb Question
Posted: Tue Oct 05, 2010 6:19 pm
by persempre907
Re: Dumb Question
Posted: Wed Oct 06, 2010 4:48 am
by Mc tool
Nah , me neither , What are you doing Antti
( I bet he is one of the dudesons )
Re: Dumb Question
Posted: Thu Oct 07, 2010 12:36 am
by higgy
I confess to scars on both knees,but no marks on my center stand, if the stand is draggin the wheels will soon be off the ground and that can never end well
Re: Dumb Question
Posted: Thu Oct 07, 2010 3:01 am
by du907
Somebody removed the center stand. To fix the side stand springing up . . . . remove the hex headed screw that holds the side stand. Notice that the hex opening is unusually deep. File or grind enough of the screw head off so that the curved plate that pivots and the springs connect to just clears the head of the screw when you put the side stand down, fixed. Don't worry, there will still be enough depth in the hex opening to be able to tighten or loosen the screw in the future.
du907
