Dyna coils + Ignitech
angelix
Post by angelix »
Today I fitted a set of Dynacoils 5 ohms on my Special SS
I am lsot for words... WOW.
the difference that makes on my bike is mind blowing.
I have to say i was a little skeptical, I must admit I was WRONG.
My engine has always had some issues when starting from a "dry" carb (ie after a couple weeks without starting it)
well the engine turned twice and the engine fired.
with a full carb (FCRs) it is already idling before even finishing the first 1 turn.
worth EVERY penny and EVERY drop of sweat I invested in making a new bracket.
:beer: :beer:
Re: Dyna coyls + Ignitech
Been there, done that, sweeet! :thumbup: :beer:
Coils main effect is starting, f me anyway.
Pics of bracket or it didn`t happend....
Btw, where are your location?
angelix
Post by angelix »
Tamburinifan wrote:Been there, done that, sweeet! :thumbup: :beer:
I guess you are right about the effect, although I also noticed that my Ignitech map seems to work differently on the first 1/5 of throttle, will have to recheck it and do some adjustments.
I am also planing of adding a TPS sensor so that we can have a multiple maps set up; The FCRs could be eventually retrofitted (it would cost a fortune tho') as there is a version that comes with it (Yamaha TRX, check Sudco catalogue), but i think I can adapt a TPS sensor from a small car , I just need to find some time to check few TPS sensor datasheets and pick the correct one
I will post a picture of the bracket asap; basically I "sort of" copied the original of the SS (the one on the Airbox under the tank) and made it slightly taller to fit the new height of the coils
I used 2mm aluminium, I am not sure if it will last (vibrations) so I think I will need reinforce it a little on one side
I live in UK since 1999, I have my SSSpecial here, whilst my 907ie plus the others non-Dukes I have are at my parents in Italy.
Re: Dyna coils + Ignitech
Batt box/bracket:
More pix: http://www.ducatisuite.com/jetkit.html
swapping coils was the first thing I did even before replacing the carb.
If you didn`t already try a lighter flywheel also (not extremely lightened though) and you`ll be surprised and ask yourself why you didn`t do that earlier - again.
angelix
Post by angelix »
paso750 wrote:swapping coils was the first thing I did even before replacing the carb.
HAHA yep... i know, i know :mrgreen: :twisted:
my SSS (SS special) is only a 750, but it has:
- straight teeth primary gear 71/37
- Heads were coming from a Paso 750 the ones
with gold rocker covers and Big valves (41/35mm).
- NCR cams ,
- FBF Pistons, effective compression is 12.2:1
- FBF Flywheel,
- shotpeened conrods/primary/gears,
- FCR39 carbs
- Dynacoils
- adjustable cam-gears with "new" belt profile (round)
- Programmable Ignitech ignition.
- lots of polishing and smoothing, lightnened rockers and of course balanced cranckshaft, rods and pistons
- Hybrid gearbox with shortened gears
the only thing I dont have is a proper antislip clutch, unfortunately being the same as the PASO it is impossible to find one unless I design it myself....
The orther thing I would love to do (actually I am working on it) is to add a TPS so that I can have multiple ignition maps.
with some differences like the modified gearbox it sounds like mine.
I just have a 780 kit instead, bigger valves and carb than yours. The rest is similar just from other manufacturers.
If you ever need another set of conrods I still have a set of polished and balanced ones. I wanted to use them myself before I found a sweet deal on the Carillos.
Sounds lovely, angelix.
Dyno`d yet?
angelix
Post by angelix »
Tamburinifan wrote:Sounds lovely, angelix.
Dyno`d yet?
nope, I am nearly close to completion
I have two videos, the first is when I started it the first time,
http://www.youtube.com/watch?v=C3K4Yax8T8c
the second after I played a little with the FCRs.
http://www.youtube.com/watch?v=n_MD_HWHe9A
the next will be in the dyno room , if i get there one day :banghead: :banghead:
http://www.youtube.com/watch?v=n_MD_HWHe9A , nice! :thumbup:
What advance high revs?
Pics of the whole bike would be nice, seems like a very nice project. :beer:
angelix
Post by angelix »
Tamburinifan wrote:http://www.youtube.com/watch?v=n_MD_HWHe9A , nice! :thumbup:
At the moment I am playing with the standard settings including the different DP AL9000 module settings.
I noticed that a smooth encrease in the advance seems to work better that sharp changes, but I guess the best would be doing it properly once fueling is definitive.
Now runs nice at idling, although I there a small void between 1500-2500 rpms which I believe it is caused by the extreme hot cam diagrams; in fact anything above 3000 rpm and the thing just explodes.
I am not very experienced with FCRs, I will get assistance form the dyno people it will take the bike to (PDQ in UK)
The big test will be on the dyno, I am very curious!
Tamburinifan wrote:Pics of the whole bike would be nice, seems like a very nice project. :beer:
you already saw some picures, here (2nd page): http://forums.ducatipaso.org/viewtopic. ... 689#p33689
:oops: , getting old....
But definately worth seeing again, lovely bike.
angelix
Post by angelix »
Tamburinifan wrote::oops: , getting old....
You tell me :-( :-(
I am loosing the use of my hands... 10-15 years ago, I could do lots of very delicate jobs in no time, now to crimp two connectors and two coil leads it took me 2 hs.
:oops: :oops:
