Unleaded
Rhino
Unleaded
Post by Rhino »
Can my 907IE run that unleaded rubbish?
Hey, come to that, can you run the 906 and the 750 (Paso and Sport) on it too?
Rhino
If God rides a Harley . . .
Then the Devil rides a Duke!
Re: Unleaded
Yes,you may want to pay attention to the octane you use
907pasonut
Re: Unleaded
Post by 907pasonut »
Rhino wrote:Can my 907IE run that unleaded rubbish?
I'm sure the motor has hardened valve seats to cope with unleaded fuel, and I run hi-octane...I think 98 on mine.
what I did do when I re-sealed the tank was to remove all the old deposits from base of tank as my bike was standing for a long time, and I strongly recomend to fit a new fuel filter once you clean the tank :thumbup:
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
Re: Unleaded
FYI....almost any engine can be run safely on unleaded fuel. The only concern would be in vehicles used for towing or competitive racing. Its all about the heat,not the material used for the valve seat or what fuel you use.
Yes back when unleaded fuel was first publicly introduced there was a lot of bellyaching about the damage that could result all of which over time proved to be an old wives tale. The simple fact is no matter what your valve seat material is it will get a good hardening during your engines break-in regardless of if you know how to do it or not :thumbup: The cooling attributes of lead deposits on your valves and seats proved to be more of a detrimental effect on valve train durability. In the end it was found to be the oil's and the fuel's cooling effects that really mattered. One more reason why direct injection finally wins over the carb!
nnnnnnorman
Re: Unleaded
Post by nnnnnnorman »
i've been putting 95 unleaded in mine for the last four year and she still pulls like the first time i rode it. :cool: :) :thumbup:
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Rhino
Re: Unleaded
Post by Rhino »
Thanks Guys
Claude - one of the problems I have with the 907 is that the bike was left standing with a full tank in a private museum for many many years. As a result the entire inside of the tank is covered with a sludge which may in time break up. Can I clean it out with anything or just change my filters like it was a religion?
Rhino
Re: Unleaded
POR has products which will do the job for you
[url]ttp://www.por15.com/[/url]
in the UK http://www.holden.co.uk/displayProducts ... andCode=Z7
nnnnnnorman
Re: Unleaded
give it a good thorough clean out :thumbup:
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Rhino
Re: Unleaded
Post by Rhino »
Thanks guys - have purchased tank cleaner from Holdens (Thanks Higgy) and will give tank a thorough clean out.
Rhino
907pasonut
Re: Unleaded
Rhino wrote:Thanks guys - have purchased tank cleaner from Holdens (Thanks Higgy) and will give tank a thorough clean out.
Rhino if the tank is in good conddition ie no corrosion a good clean will be all its needed, if there is a lot of gunk it would be good to remove the fuel pump and clean the inlet strainer, but its a bit of work to dismantle tank components, the fuel pump is only clipped in by 2 plastic clips, when you fit the hoses back make sure you have good clamps and tighten them up (dont overtighten) as there is a fair bit of pressure in EFI, also...when you finish just put enough petrol in tank to prime pump and stick a torch in there to check for petrol leaks on joints...have fun :evil:
its a glorious day here just about to leave for a ride with the ducati club and should meet up with Nigel :thumbup:
Cheers Claude.
Re: Unleaded
It is a good idea to remove the pump and strainer and any plastic bits before treating the tank. POR-15 generally provides great instructions with their products and they work very well when followed to the letter. You can also download the instructions from the website :thumbup:
Re: Unleaded
You'll probly all cringe in horror :shock: but ( after 1st removing all the fittings ) I have cleaned various tanks out by 1/4 filling them with wet gravel and sand , and giving them a good shake about , aparently steel shot is the go but I didnt have 10 kilo's of that
Re: Unleaded
Mctool's media blasting method :lol: :lol: :lol: :lol: :lol:
crude but effective as long as you get ALL the media out :wacko: :wacko: :wacko:
Rhino
Re: Unleaded
Post by Rhino »
Nothing like B.F.I. eh Mc tool? I should know - it usually works for me.
Thanks for all the tips guys - we'll try to get her back on the road - where she should be - soon (just in time for the Welsh Winter - force 7 last week with freezing rain coming in off the Irish Sea on the horizontal!!)
Ride safe Guys
Rhino
Re: Unleaded
Rhino , sorry to hear about the wether( snigger ) . Its 1/2 8(am ) and there is not a cloud in the sky here , but Ive been on my bike :P , in the sun( :D ) so much lately :) that I think Ill take crapi for a drive instead
seeing as how Ive just shoe horned a 3.5 rover in there( Buick 300 for the americans ), Tally ho :) :)
