Page 1 of 2
Unleaded
Posted: Thu Nov 18, 2010 12:50 pm
by Rhino
Can my 907IE run that unleaded rubbish?
Hey, come to that, can you run the 906 and the 750 (Paso and Sport) on it too?
Re: Unleaded
Posted: Thu Nov 18, 2010 2:20 pm
by higgy
Yes,you may want to pay attention to the octane you use
Re: Unleaded
Posted: Thu Nov 18, 2010 9:19 pm
by 907pasonut
Rhino wrote:Can my 907IE run that unleaded rubbish?
I'm sure the motor has hardened valve seats to cope with unleaded fuel, and I run hi-octane...I think 98 on mine.
what I did do when I re-sealed the tank was to remove all the old deposits from base of tank as my bike was standing for a long time, and I strongly recomend to fit a new fuel filter once you clean the tank
Re: Unleaded
Posted: Thu Nov 18, 2010 11:00 pm
by higgy
FYI....almost any engine can be run safely on unleaded fuel. The only concern would be in vehicles used for towing or competitive racing. Its all about the heat,not the material used for the valve seat or what fuel you use.
Yes back when unleaded fuel was first publicly introduced there was a lot of bellyaching about the damage that could result all of which over time proved to be an old wives tale. The simple fact is no matter what your valve seat material is it will get a good hardening during your engines break-in regardless of if you know how to do it or not
The cooling attributes of lead deposits on your valves and seats proved to be more of a detrimental effect on valve train durability. In the end it was found to be the oil's and the fuel's cooling effects that really mattered. One more reason why direct injection finally wins over the carb!
Re: Unleaded
Posted: Fri Nov 19, 2010 12:27 pm
by nnnnnnorman
Re: Unleaded
Posted: Fri Nov 19, 2010 1:48 pm
by Rhino
Thanks Guys
Claude - one of the problems I have with the 907 is that the bike was left standing with a full tank in a private museum for many many years. As a result the entire inside of the tank is covered with a sludge which may in time break up. Can I clean it out with anything or just change my filters like it was a religion?
Re: Unleaded
Posted: Fri Nov 19, 2010 2:37 pm
by higgy
POR has products which will do the job for you
[url]ttp://
www.por15.com/[/url]
in the UK
http://www.holden.co.uk/displayProducts ... andCode=Z7
Re: Unleaded
Posted: Fri Nov 19, 2010 6:22 pm
by nnnnnnorman
give it a good thorough clean out
Re: Unleaded
Posted: Fri Nov 19, 2010 6:53 pm
by Rhino
Thanks guys - have purchased tank cleaner from Holdens (Thanks Higgy) and will give tank a thorough clean out.
Re: Unleaded
Posted: Fri Nov 19, 2010 9:48 pm
by 907pasonut
Rhino wrote:Thanks guys - have purchased tank cleaner from Holdens (Thanks Higgy) and will give tank a thorough clean out.
Rhino if the tank is in good conddition ie no corrosion a good clean will be all its needed, if there is a lot of gunk it would be good to remove the fuel pump and clean the inlet strainer, but its a bit of work to dismantle tank components, the fuel pump is only clipped in by 2 plastic clips, when you fit the hoses back make sure you have good clamps and tighten them up (dont overtighten) as there is a fair bit of pressure in EFI, also...when you finish just put enough petrol in tank to prime pump and stick a torch in there to check for petrol leaks on joints...have fun
its a glorious day here just about to leave for a ride with the ducati club and should meet up with Nigel
Re: Unleaded
Posted: Fri Nov 19, 2010 11:30 pm
by higgy
It is a good idea to remove the pump and strainer and any plastic bits before treating the tank. POR-15 generally provides great instructions with their products and they work very well when followed to the letter. You can also download the instructions from the website
Re: Unleaded
Posted: Fri Nov 19, 2010 11:55 pm
by Mc tool
You'll probly all cringe in horror
but ( after 1st removing all the fittings ) I have cleaned various tanks out by 1/4 filling them with wet gravel and sand , and giving them a good shake about , aparently steel shot is the go but I didnt have 10 kilo's of that
Re: Unleaded
Posted: Sat Nov 20, 2010 1:38 am
by higgy
Re: Unleaded
Posted: Sat Nov 20, 2010 10:13 am
by Rhino
Nothing like B.F.I. eh Mc tool? I should know - it usually works for me.
Thanks for all the tips guys - we'll try to get her back on the road - where she should be - soon (just in time for the Welsh Winter - force 7 last week with freezing rain coming in off the Irish Sea on the horizontal!!)
Ride safe Guys
Re: Unleaded
Posted: Sun Nov 21, 2010 8:04 pm
by Mc tool
Rhino , sorry to hear about the wether( snigger ) . Its 1/2 8(am ) and there is not a cloud in the sky here , but Ive been on my bike
, in the sun(
) so much lately
that I think Ill take crapi for a drive instead
seeing as how Ive just shoe horned a 3.5 rover in there( Buick 300 for the americans ), Tally ho
