Hi Guys,
can you tell me wich Ducati-rims fit on a 907?
Does th 851-Rim fit? Or a SS-Rim?
/ Edith: is it correct, that these would fit?: SS/SL/M/851/888 in Front, and 400-900SS/SL,Mon in rear?
BR,
Johannes
Wich rims fit on a 907?
- JoKing
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
Re: Wich rims fit on a 907?
you mean as 1:1 replacement ?
I guess that`s the question as generally you can use whatever rims you want with spacers etc.
- JoKing
As a 1:1 replacement, at first, yes.
Ok... monoswingarm types do not fit, thats clear.
And many are just "swappable"?
86` Ducati 750 Paso
86` Ducati 750 Paso
- ducbertus
rimsize 3.5 x 17
and Ø 17 mm axle size. this means Marzocchi or maybe early Showa upsd forks
so anything pre 1994 I would say
required spacers are easy to machine or obtain.
bertus
bertus
400-750 all models have 4.5" rear wheel.is it correct, that these would fit?: SS/SL/M/851/888 in Front, and 400-900SS/SL,Mon in rear?
