Another dash related issue
Has anyone taken their odometer apart?
Mine started working intermittently so I suspect one of the plastic gears broke.
I've seen places that fix this in the US but this bike is in Germany,
so I'm considering taking it apart.
Anything to watch out for / not break something else?
Odometer
Re: Odometer
intermitent issues are not likely to be internal to the speedo,more likely a cable, drive or receiver issue
If in fact it proves to be internal be very careful and good luck finding parts aside from a spare speedo
Get your cluster installed properly and check that cable then go from there
Re: Odometer
higgy wrote:intermitent issues are not likely to be internal to the speedo,more likely a cable, drive or receiver issueIf in fact it proves to be internal be very careful and good luck finding parts aside from a spare speedo
When it works it does one full rotation then stops again. Starts working when I hit a bump.
The trip meter works consistently so I'm inclined to think it's a gear.
Thanks for the suggestions.
Re: Odometer
could still be the cable,if either end is worn
- JoKing
Re: Odometer
Don`t think so, when the trip meter still works.
Maybe i have a used, but working odometer somewhere...
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
Re: Odometer
JoKing wrote:Don`t think so, when the trip meter still works.
That would be great. Thanks.
- JoKing
Re: Odometer
I found it.
The dash holding rubber/screws you should purchase somewhere else. I paid much too much for them.
The fairing stay rubbers i got as well. You got a PM.
86` Ducati 750 Paso
86` Ducati 750 Paso
