Odometer
Posted: Mon Mar 07, 2011 10:31 pm
by plasmid
Another dash related issue
Has anyone taken their odometer apart?
Mine started working intermittently so I suspect one of the plastic gears broke.
I've seen places that fix this in the US but this bike is in Germany,
so I'm considering taking it apart.
Anything to watch out for / not break something else?
Re: Odometer
Posted: Mon Mar 07, 2011 11:21 pm
by higgy
intermitent issues are not likely to be internal to the speedo,more likely a cable, drive or receiver issue :thumbup: If in fact it proves to be internal be very careful and good luck finding parts aside from a spare speedo :wacko: Get your cluster installed properly and check that cable then go from there :?:
Re: Odometer
Posted: Mon Mar 07, 2011 11:53 pm
by plasmid
higgy wrote:intermitent issues are not likely to be internal to the speedo,more likely a cable, drive or receiver issue :thumbup: If in fact it proves to be internal be very careful and good luck finding parts aside from a spare speedo :wacko: Get your cluster installed properly and check that cable then go from there :?:
When it works it does one full rotation then stops again. Starts working when I hit a bump.
The trip meter works consistently so I'm inclined to think it's a gear.
Thanks for the suggestions.
Re: Odometer
Posted: Tue Mar 08, 2011 4:06 am
by higgy
could still be the cable,if either end is worn
Re: Odometer
Posted: Tue Mar 08, 2011 11:57 am
by JoKing
Don`t think so, when the trip meter still works.
Maybe i have a used, but working odometer somewhere...
Re: Odometer
Posted: Tue Mar 08, 2011 12:42 pm
by plasmid
JoKing wrote:Don`t think so, when the trip meter still works.
That would be great. Thanks.
Re: Odometer
Posted: Tue Mar 08, 2011 7:58 pm
by JoKing
I found it.
The dash holding rubber/screws you should purchase somewhere else. I paid much too much for them.
The fairing stay rubbers i got as well. You got a PM.
