Left M1r fork leg needed!
Posted: Fri Apr 15, 2011 1:00 am
by Tamburinifan
The one w no rebound fuction.
My wheel axle threads are gone, need just the lower part of left M1r leg.
Re: Left M1r fork leg needed!
Posted: Fri Apr 15, 2011 4:44 am
by 907pasonut
try iangowanloch@bigpond.com he may have one...good luck :beer:
actually this one might be better gowanloch@ozemail.com.au
Posted: Sun May 29, 2011 10:35 am
by avhpaso
did you find a leg I am looking for the RH side leg
Posted: Sun May 29, 2011 3:04 pm
by Tamburinifan
Not found.
Posted: Sun May 29, 2011 3:19 pm
by paso750
if Gert finds one it won`t help you as the 907ie fork is not the same.
Posted: Thu Jun 02, 2011 9:31 pm
by Duc750
I thought the lower was the same but the actual tube longer, or are the threads different too?
Posted: Fri Jun 03, 2011 8:31 am
by paso750
the 907ie has 40mm brake caliper mounts, the P750/906 has 108mm.
Gert has a 907ie, avhpaso a P750.
Posted: Fri Jun 03, 2011 9:52 am
by Duc750
Got you, wasn't thinking about calipers (but should have been)
Posted: Mon Jun 06, 2011 10:53 am
by paso750
seen this ?
It doesn`t say which Paso it`s from, the price is a bit high and the position of the left dust seal looks a bit odd considering all seals were replaced :mrgreen:
http://cgi.ebay.de/Marzocchi-fork-41-7- ... 415a61a926
Posted: Tue Jun 07, 2011 9:50 pm
by angelix
paso750 wrote:seen this ?
I sent the seller an email and he confirmed that the forks have caliper supports 108mm apart, whiche means they are either P750 or P906 as the 907 has the supports only 40mm apart.
the guy told me the total lenght is 810 mm from standing free on the floor to the top of the valve on top of the fork and the distance from bottom to center first hole of the caliper support is 95 mm.
