Not mine, nor do I know the seller.
http://cgi.ebay.com/ebaymotors/Cagiva-D ... _500wt_956
Giant offset front sprocket for early models that didn't have the 3mm shims between the motor and the frame on the right side. Also good for running 180 -16" rear tires. Check your chainline if you buy it.
Rare C/S sprocket
- ducinthebay
Rare C/S sprocket
Re: Rare C/S sprocket
I had one of those and the offset is way more than required even with a 180 tire. At least on a Paso 750 that is.
They are not that rare btw. I ordered a new one from
http://www.motorrad-tuning-zubehoer-tei ... j.-1987-na
Getting it was no problem. They have them in 14 an 15 teeth. Price is €32-34 ($45-49).
