Well, almost any shape. I want the basic shape to do a fiberglass lay-up of them to create a Paso-esque fairing for a custom 750 Sport. (Its a long story, and if it works out well, I'll post pictures, if it doesn't work out, I will disavow any knowledge of the project)
Anyway, I need a left and right mirror, and I'll even send them back to you after I do a mold of them. Need the signal lenses in them. Scratched and scraped are fine. I might do a bit of body work on it to get it back to the original shape. If you want them back, I'll have then about a month. If you want to sell me some damaged ones, send me a pic and we can discuss.
I don't need the actual mirror glass (the reflective bit) , just the pod/fairing bit.
Phil
Wanted - Paso mirror pods - any shape
- ducinthebay
- englishstiv
Re: Wanted - Paso mirror pods - any shape
I have two "spare" and very new and unused Far copy ones you can use both unpainted with lenses so with plenty of release wax on you should not damage them. - I hope???
Only issue is I live over the other side of the pond.
I would want them back though
The other alternative is to do a lay up here and package that to you.
If no one closer it may help?
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- ducinthebay
Thanks for the offer, but I found some locally, as in on my shelf, inside the fairing.
