907 Fuel Cap leaking
2vtwin
Post by 2vtwin »
So the area around the fuel cap has started leaking, more of a weeping, after some investigation it would appear it is coming through at the bolts, rather than the outer part of the ring or the seal between the cap and the ring. I replaced the gasket under the outer ring with NOS gasket but not exactly sure it was the right part, the bolt pattern was the same, but the holes maybe a little larger and the rubber curls up slightly once the bolts are tightened. Anyone else had a similar problems? I'm thinking I should start with a gasket I know is the correct part number, anyone know of a source? Any other ideas? Thanks - Gene
"It's about the Journey, Not the destination"
AMA Charter Life Member, Victory Motorcycle Club, Charter Member, Patriot Guard Rider
02' M900
01' Victory SC
04' Victory KP
09' HD XR1200
14' Ducati Diavel
16' Victory Cross Country Tour
900streetfighter
Re: 907 Fuel Cap leaking
Post by 900streetfighter »
Might be the breather pipe that fits to the cap. I had similar problem,that was the cure.
