parts
duc24u
parts
Post by duc24u »
I need part # 28740011a or magneti marelli aei 450 b if i cannot find this part will be forced to part out bike :,(
Bock900r
Re: parts
Post by Bock900r »
Is there a claer name or picture for this?
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
duc24u
Re: parts
Post by duc24u »
it is called the ignition module or power module two modules on either side of a heat sink.
duc24u
Re: parts
Post by duc24u »
you have a 907 ie then you can see it located next to the regulator and the ignition relays under the left fairing by the mirror. Und danke auch fur alles jeder kann hier nicht melden.
Bock900r
Re: parts
Post by Bock900r »
Now I know what yoiu mean. I can't see it, I am working in Serbia for some weeks.
I had seen these on Moto Guzzi Modells. May be they use the same.
I have no spare. good luck
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
angelix
Re: parts
Post by angelix »
all the Magneti Marelli setup of the 907 (MarelliP7) was used in many other automotive aplications so, maybe, you can find these parts right of the web (or ebay) through a car parts dealers
That part was also used in the 851-888 and I think in the first series of the 916 (Marelli P8)
In the cars, I think it was on the Lancia HF, 4WD, Thema, Fiat Croma, just to name a few.
I will ask a friend who is a Marelli specialist (and vintage car collector :mrgreen: ) hoping he can help
angelix
Re: parts
Post by angelix »
On EBAY USA there is ONE attached to a wiring loom
worth giving the guy a call!!!
http://www.ebay.com/itm/Ducati-907ie-90 ... fa&vxp=mtr
duc24u
Re: parts
Post by duc24u »
Thank you will try that
nojapan
Re: parts
Post by nojapan »
angelix wrote:all the Magneti Marelli setup of the 907 (MarelliP7) was used in many other automotive aplications so, maybe, you can find these parts right of the web (or ebay) through a car parts dealers
also laverda zanè!!
Gabriel
Paso 750
Elefant 750 Monofaro '88
Elefant 900 Monobraccio '89
Elefant 750 pure off '85
SS 750 '92
Laddie again
Re: parts
Post by Laddie again »
It's not that serious...
It would be "nice" to have the original but not absolutely necessary...
the ignitors are a problem to get now but were used on various cars and bikes around the time of production of the 907...so there will be some around - just need to look hard.
Also, they are a common thing...although they LOOK the same they AREN'T the same function...it is possible to use other model ignitors BUT re-wire the connections correctly to match the 907 requirements.
ducbertus
Re: parts
Post by ducbertus »
Hi Duc24u,
you may contact Carmo at www.carmo.nl
When I'm correct you'll need BB1105(A), BB1135
Personally I've no experience with this company, but would thrust them
Bertus
Bock900r
Re: parts
Post by Bock900r »
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
Ducolaf
Re: parts
Post by Ducolaf »
Visited yesterday Ducaparts in Twello the netherlands with parts they have from desmantling damaged or broken bikes. Have a lot of stuff and prices are not like you see on Ebay. K&N filter for the Paso just € 20,- instead of €60 or more.
Perhaps drop them a mail, they speak English and with the partno now what you need. ducaparts at motofun dot nl
Proud owner of a;
- Ducati 907 ie 1992 in red
