Old age is hitting hard all the rubber bits on the 907. Slowly working my way through them all. Found one of the Airbox to Throttle body adaptors to be perished (Part No: 80110031A). Ducati no longer stock the item (where have I heard that before?). Does anyone know of an aftermarket version?
Failing that, does anyone have a good aftermarket setup? Maybe a K&N setup? (Part No's would be good)
Cheers.
Airbox to Throttle body rubber
Re: Airbox to Throttle body rubber
You could try a carburetor gasket Ducati part # 037095010 it may work.
