Are they still available? Hi, I'm new on these forums and have a few questions about Pasos. The firs one being the tires. I have 120/80-16 M/C 60T front in excellent shape and 159/80-16 71H rear, to be replaced.
1. Are the sizes right?
2. If not, what should I fit?
3. I've got issues with the Weber carb diaphragm
4. I need new clutch discs, any recommendation? Are Khamma (Germany) ok?
If you are not the expert on these general topics, please refer me in the right direction.
Thanx
new member with questions
Re: new member with questions
Hi,
as you`re new just some general (unwritten) forum rules. Do check the manuals first and use the forum`s search function. Then please open your own thread unless your questions fit to an existing one.
1. no
2. see user manual or FAQs
3. what`s the question ?
4. Kämna doesn`t make clutch discs. The most common are ADIGE or SURFLEX.
PS: adding your location to your profile would help
1. no
I think these tire sizes are wrong. I use in my Paso 130-70-16 and 180-60-16. I used 150-80-16 and this size is very high tire and the 5th gear is very, very long, and it is very thin and lose grip suddenly when you are inclined.
70 hp. can change the world
