new member with questions
Posted: Fri Nov 23, 2012 7:26 pm
by Dego
Are they still available? Hi, I'm new on these forums and have a few questions about Pasos. The firs one being the tires. I have 120/80-16 M/C 60T front in excellent shape and 159/80-16 71H rear, to be replaced.
1. Are the sizes right?
2. If not, what should I fit?
3. I've got issues with the Weber carb diaphragm
4. I need new clutch discs, any recommendation? Are Khamma (Germany) ok?
If you are not the expert on these general topics, please refer me in the right direction.
Thanx
Re: new member with questions
Posted: Sat Nov 24, 2012 10:07 am
as you`re new just some general (unwritten) forum rules. Do check the manuals first and use the forum`s search function. Then please open your own thread unless your questions fit to an existing one.
1. no
2. see user manual or FAQs
3. what`s the question ?
4. Kämna doesn`t make clutch discs. The most common are ADIGE or SURFLEX.
PS: adding your location to your profile would help
Posted: Sun Nov 25, 2012 10:52 pm
by pompone
I think these tire sizes are wrong. I use in my Paso 130-70-16 and 180-60-16. I used 150-80-16 and this size is very high tire and the 5th gear is very, very long, and it is very thin and lose grip suddenly when you are inclined.
