Radiator Coolant tank mod
nickta
Post by nickta »
Hi.
Had a look at the Documents for the 906 and 907, and found the modification to the Coolant tank. Ordered the filler neck from the Honda dealer, but the Radiator cap comes in 2 different pressures. Choices are 1.1 Bar, or 0.9 Bar. They have an after market cap in 0.9, but not the 1.1. Any thoughts on which size would be best? Haven't had a look in the 907 Maintenance manual (not home), but guess either would be OK?
The other question with this mod, it says "cut a slit from the I.D. to just beyond the cap’s inner relief valve". I gather this bit gets the inside of the tank to Atmospheric pressure, but is it obvious how far the slit goes? Anyone done this mod and have a picture?
Cheers.
Nick.
Re: Radiator Coolant tank mod
Nick,
I obviously wouldn`t know as I have a P750 but in case you`d use Evans waterless coolant (anyone tried ?) there would be no pressure in the system at all.
http://www.evanscooling.com/
The cap on my 906 has been knackeded sinse I have had it and it runs zero pressure and has always worked fine . The cap is only there to keep the coolant in when I get airborne :D
nnnnnnorman
Post by nnnnnnorman »
gotta watch out for those humpback bridges hammish :cool:
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
romus
Post by romus »
nickta wrote:...The other question with this mod, it says "cut a slit from the I.D. to just beyond the cap’s inner relief valve". I gather this bit gets the inside of the tank to Atmospheric pressure, but is it obvious how far the slit goes? Anyone done this mod and have a picture?Nick.
I mucked around like that for my first mod. Just redid it since I wiped it off in a crash. This time I just snipped all that pressure spring control part out of the cap with tin snips and drilled a very small hole in the cap, to let a small amount of air flow. Works fine.
nnnnnnorman wrote:gotta watch out for those humpback bridges hammish :cool:
Not the humpback that's the problem , its the old people hiding on the other side :D
Hi nnnnnnorman
Hamish
