Radiator Coolant tank mod
Posted: Sat Jan 11, 2014 8:33 am
Hi.
Had a look at the Documents for the 906 and 907, and found the modification to the Coolant tank. Ordered the filler neck from the Honda dealer, but the Radiator cap comes in 2 different pressures. Choices are 1.1 Bar, or 0.9 Bar. They have an after market cap in 0.9, but not the 1.1. Any thoughts on which size would be best? Haven't had a look in the 907 Maintenance manual (not home), but guess either would be OK?
The other question with this mod, it says "cut a slit from the I.D. to just beyond the cap’s inner relief valve". I gather this bit gets the inside of the tank to Atmospheric pressure, but is it obvious how far the slit goes? Anyone done this mod and have a picture?
Cheers.
Nick.
Cheers.
Nick.
