Ducati Regulator replacement help needed
englishstiv
Post by englishstiv »
Hi folks I need to source a new Regulator silly prices this country so far but have seen this one Stateside however the postage seems very expensive ...so is there anyone that side of the pond that might know if it can be sourced and posted cheaper?
http://www.ebay.co.uk/itm/Ducati-907-i- ... 35d256e6c5
Or is there a possibility of one somewhere else in this big old world of ours?
Thank you :thumbup:
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Re: Ducati Regulator replacement help needed
Stiv, have you tried http://ricksmotorsportelectrics.com/
That is where I found mine
this looks the same. The M900 1995 is listed also in the auction you posted. If it`s the Electrosport ESR510 it`s what you`re looking for. (If it`s not they might be able to get the correct part for the same price). I`d ask.
http://www.ebay.co.uk/itm/Ducati-M900-M ... 1e74438f73
This one incl. shipping is even cheaper but if it comes with that connector it will require a little modification. You`ll have to ask also here ;)
http://www.ebay.de/itm/Laderegler-fur-D ... 19e93fd46f
du907
Post by du907 »
Derek
Post by Derek »
englishstiv wrote:Hi folks I need to source a new Regulator silly prices this country so far but have seen this one Stateside however the postage seems very expensive ...so is there anyone that side of the pond that might know if it can be sourced and posted cheaper?
Thank you :thumbup:
I have a working regulator that I took off my 907ie. The only fault is that the plug for the alternator wires has slightly melted due to a bad connection. I replaced it with a Mosfet regulator from a MTS1200 so it is now spare. You can have it for £20 + postage.
englishstiv
Thank you folks. Derek thank you I have PM'd you.
DUCATI 907ie 1992
Derek
Post by Derek »
If you aren't bothered about the warning light there are a great many regulators that can be used and if you want to retain the warning light you can fit one of these, like I did. http://www.improvingclassicmotorcycles.com/products.htm
Use a positive earth version with the pink wire connected to ground the charge warning light, the black to earth and the red to the switched feed from the ignition.
