907ie Turn Signals On -Lights blink
caryboat1
Post by caryboat1 »
Just noticed that when my turn signals are on that the headlights blink, idiot lights and rear light all flash faintly w the signal flasher.
Ideas? sounds like a ground somewhere
thx
Kevin
Re: 907ie Turn Signals On -Lights blink
Yep , sounds like a faulty ground , well that's where id be lookin 1st :) .
Derek
Post by Derek »
That's what I thought too with mine but after checking all the grounds and finding nothing I tracked it down to poor connections in the ignition switch. With the headlight on it was dropping over 1V across the ignition switch. My solution was to was to fit a relay to take the current. The original thread is here. http://forums.ducatipaso.org/viewtopic.php?f=3&t=6344
