Swingarm
Uwe
Swingarm
Post by Uwe »
Hello
Has anyone tried if the swing arm 906 fits in the 907ie. ??
The problem could be the 17-inch tires.
regards
Uwe
Re: Swingarm
the front part of the swingarm is identical so it will fit engine and frame but it`s a little shorter, it has a different width, a different axle diameter, the pin that holds the rear caliper bracket is in a different position so the bracket of the 907ie won`t fit etc.
